I need the dimensions for the front lift rod on the manual lift 200 series tractor 210-216. I have a model 43 blade but I don't have the lift rod for the 214. If any one is willing to measure their lift rod it will be greatly appreciated.
Thank you Diesel.Ill go outside and check.
Thanks Diesel, this helps a lot.It is 37 1/2" long with a slight bend in the middle. The one end that attaches to the tractor has a 3/8" dia. by 1 1/2" long pin. The other has an 1 1/2" long notch in it that connects to the blade.
