Wet sand it. Start with 220 or 320, depending on how bad it is. Then turn your hose on real low or get a squirt bottle and keep the steering wheel wet while you sand. Work your way up in grit until about 2000 grit. It'll look brand new if you take your time. Use circular notions as much as possible and always keep moving rather than stay in one spot. Once its sanded good with 320, move up to 600 and repeat. Then either 1000 or 2000 and finish with 2000. Then you can buff it. It'll take a little more time than putting oil on, but when your done it won't need oil. The damaged area will be removed, it'll be new.
well, it rained today..no grass cutting...so i started the steering wheel sanding..
i started with, and completed 220#, had to come inside and cool off, too hot for this today.
now, after i finished, i wiped off steering wheel..to get it clean and check on progress..
the steering wheel is now a LIGHT gray...not what i expected. :crybaby:
the way i figure it..i continue on and follow through to see FINAL results...
or..
i am still in that oxidized gray layer and should continue with 220 or even 150# until i get through that layer and it starts to turn black..
unfortunetly, i think it's the latter.
i find it difficult to believe though because i did a thorough job on that first sanding.
guess i'll start testing a small spot... :dunno:
