Hi folks! I'm well into my Snapper 30113S restoration, and most of the chassis has been put back together. Now comes the engine restoration.
The engine was running pretty well considering it sat unused for 10+years. I removed and cleaned the carburetor, and have ordered a rebuild kit. I'm also replacing rusted out exhaust system with new. I've removed the engine cowlings, and am in the process of cleaning & repainting.
I also want to repaint the engine, but with 20+ years of gunk to remove in order to prep for paint, I really need some advice:
1) What is the best way to clean/degrease the engine? I spent 3 hours removing the heaviest deposits by hand with some degreaser and a wire brush, but there are places (cooling fins especially) that I can't reach. I've got a power washer, but logic tells me high pressure water and engines don't mix. Any recommendations?
2.) When priming and painting, should I use a high temperature paint?
Any other tips/tricks for engine restore would greatly be appreciated. The attached pictures are an example of the current state of the engine paint. Thanks!!!
