I was able to get some time on it today and I'm very impressed. The best way I can describe it is "natural" -- it does what it does easily and well.
I took two trips out to the fence line hauling yard debris in the polycart, and it worked like a charm.
On the way back I mowed a strip for the first time -- cut it a bit too close, I'll have to adjust the deck height.
Everything seems to be in ship-shape. I do have a couple of nitpicky questions from other owners though:
1. My parking break squeaks and groans when the pedal is actuated (sounds like a squeaky spring). Anyone else have that? I'm assuming it may wear off as the spring gets use.
2. The ignition hole seems to be getting scratched up from the key. It's not a big deal, just curious if that is the way it is or if I'm too quick with the key.
3. On start up the engine seems to "hunt" or "surge" up and down for a 10 or 20 seconds. Then it is consistent. Anyone else?
Thanks,
hpf
Thanks,
hpf
