Hello, QOS -
The pictures in the link to Net Tractor were given to me by someone that actually did the conversion. I have
not done the conversion myself although I did promise to do it when the next opportunity appears on one of my Yanmars. It's been 4 or 5 years since my last swap out with OEM Yanmar parts for a electrical charging system failure. And, although I thought the components were a little pricey at that time, I did figure that the original voltage regulator and limiter lasted 30+ years, simple removal and install with the new parts in less than an hour and I'm all set for the next few decades. In terms of a fast, permanent repair and getting your tractor back to work there is no substitute for OEM parts replacement...
I would only recommend the alternator conversion for those that want/need the additional voltage for rear and front work lights (especially for those that work their FEL at dusk or night), power inverters for available 120V AC, 12V outlet (cell phone charger-trouble lights etc.) or a radio.
The GM, 1 wire conversion is the simplest for wiring and offers several different amp output ranges but it does bypass your warning light on the dash. The GM, 3 wire is as above but requires a little more thought in the wiring... but it also provides for direct wiring to your dash warning light. Both will require a longer belt, spacers (or washers) and a longer alternator bracket. There are alternators available with a narrow body and will fit snugly in front of the radiator hose...The second, biggest advantage using the GM alternators (IMHO) is if, or when they fail, it's a simple matter of replacing the internally regulated diodes by splitting the case and removing on set screw per diode, about $6 last time I did one, and they are readily available from any auto parts store.
One does have to be a little careful when selecting the right alternator. Here's a link to one I would not purchase as it would probably work in every application but, it's only 40 amps, and little more than the OEM charging system:
http://www.db-starter-alternator.co...or.com/p-3641-new-alternator-john-deere-tractors-skid-steer-yanmar-and0197.aspx
Mark
