Does anyone have this assembly? I would like to buy one. The nearest I've came is an ebay deal but I don't have 400. to spend. I don't care if its NOS or used or ? I need the mounting brackets more than any thing.
One other thought EZ, I had that Conquest that had a spring assist for lifting the tiller. Now you would think that a spring would not make that much difference. But I tried to lift the tiller without the spring and could not budge it off the ground. Put the spring on dial the tension right, easy up.You are smart on this EZ, you will like the electric lift. It looks pretty stout. Burntime is right on all that stuff, he knows it. I agree that the lift is momentary so lights could dim,big deal. With those low draw LED's that would help. But a few more amps and bigger battery would make life easier. Keep t all fully charged with battery charger or trickle.
Remmeber alternators/generators really don't charge a battery, they just maintain the charge while running the engine. Starting an engine with a real dead battery can burn up an alternator or generator. You may slip by, but best practice is to have it all at full charge before the snow blowing begins.
That is gonna be a slick set-up. If it will lift a tiller should lift that blower as well, they are both heavy. Cool!!!!!!!!!!!!!!!!!
Neat, so if you use the electric lift EZ, and the Spring, (like Coach John has tried) you could have the best of all worlds:fing32:EZ, When I can find the photos, added a bracket with spring to the lift lever below the tractor. When the blower is down, the spring is under tension, and helps to lift. I mounted it to the frame, were the running boards and frame bolt together on the RH side. Looking to add a bit more next year to help, or find the setup you have, which is even better.
