Just doing this thread so I have a track on this project and anyone facing similar issue can see how I did mine. First the backstory; my wife and I replaced the liner about 9 years ago, actually had the pool company do it. When they put it in they said that the retainer for the liner was really bad and this was probably the last liner that it would hold. About 5 years ago I started having issues with the liner staying in the track and tried several methods to hold it in place but the retainer was rusting out pretty bad.
In this picture you can see where the liner is sagging due to the retainer not holding:
About a month ago I started to notice that the pool was "evaporating" at an increasing rate. I found the culprits pretty quick because of their size:
Bought some patch material and attempted to patch those after I drained the water to just below them, and then this happened at a corner and that was the death of the liner:
Pools don't add that much value to home in PA...at least until we can start growing cactus!! And I don't swim as much as I used to so rather than investing $50K for a $15K value I've decided to eliminate the pool. The rest of this thread is dedicated to the work and equipment that I've decided to use to get it done:
Considerations:
1. save as much deck concrete for use in other places as possible, i.e. pad for workshop entry, pad for spare vehicle next to garage, place next to highway to meet asphalt at end of driveway to give concrete pad onto my driveway, and other uses as I think of them. I have some pretty large concrete slabs around the pool so that is my hope to use them. May work or may not we'll see. Anyways to pull this off at all I need to separate the concrete from the sides of the pool so I bought a Vevor electric concrete saw (2600 watts requires generator with 30 amp outlet) to cut the concrete. Here is about what 30 seconds of runtime did (it was blowing the circuit breaker on the house that fast), no review or recommendation yet until I can use it longer:
It does have water suppression on the blade for dust and it seems to do a good job of that.
Anyways I priced rental generators and they would cost about 50% of buying one after just a few days so I ordered one online and it should be here this week; more on that later.
This morning, I went to the local rental tool place and asked about renting equipment, an excavator (Kubota U27) and track loader (Kubota 65-2), and both rent at $1300 weekly (56 hours of use) and the trailer to move them is $75 per day.
So this is my math so far:
Sunk costs:
Vevor Electric Concrete Saw $280
Powersmart Generator $475
Total Sunk Cost $755
Estimated Cost:
Topsoil: 35.65 cu. yd
Fill Dirt: 136.89 cu. yd
Total for material $2,260.15
Excavator Weekly: Kubota 65-2 $1300
Track Loader Weekly: Kubota U27 $1300
Dumpster (20 yards): $941.01
Est. Project Cost $6,655.00
And about $300 for trailer rental to move machines
Considerations:
Sunk costs:
Estimated Cost:
