Hello
We are working on a Tecumseh mv100s engine and we needed to remove the crankshaft to replace some bearings but we did not realise that the crankshaft had needle bearings. As we tried to remove the crankshaft with a rubber hammer all of the needle bearings fell out onto the patio/yard. We gathered up all we could and we found out that we needed 37 needle bearings but we only managed to find 36 so one missing (which is always the case!) So now we are looking to buy loose needle roller bearings (rounded ends) to replace the missing item.
I did a measurement of the needle roller and it came out as 1.97mm diameter by 12.50mm length. I cannot find any with those measurements so my question is would a 2mm by 12mm roller bearing be ok as a replacement or do they need to be the exact measurment?
Thank you kindly in advance for your assistance and advice.
Oniongrower
United Kingdom
Oniongrower
United Kingdom
