Solis has come out with the Electric Tractor. It seems to be targeting the home owner with small acreage. I do not know the price, but if the price was right would you be interested?
Not in the least.....but if the price was right would you be interested?
Agree, well said.This is an interesting AND informative topic please keep any political references out of the responses.
You don't have to like Electric powered stuff....whether cars or OPE, but it is what it is going to be like in the not distant future...as discussed before, run time on a charge, and battery life are problems that hold electric equipment back. But, that is being worked on.....it seems to have or exceed the power of a diesel...no trouble starting, quiet....no oil changes...there is a lot to be considered in a favorable light...I would definitely have one if the battery shortcomings are worked out
Good point you bring up. I know that EVs are quite heavy, making them much more dangerous in accidents and that would increase car insurance I’m sure.Maybe a flex. Automotive EV's have been around for quite awhile. They are still infants after over a hundred years.
RR has been running flex technology for a long time. But those locomotives need to be heavy.
My thoughts is if they can't get the weight within reason these small utilities will never fly.
I am only good to 11000 lbs.
Then half as much again in a few years time when the batteries go bad. They, industry, has a long way to go before I'd consider anything in any kind of electric vehicle.He didn't mention the price. I'll bet it's twice as much as a diesel.
I understand your reasoning but then you have two power sources to maintain, batteries, electric motor and generator plus control electronics and a diesel engine so I don't see the advantage.I have been saying for years now that the best way to make an electric vehicle would be to have a small diesel engine operating at its optimum efficiency rpm and never leaving that rpm. Let it power a generator that is keeping a power bank topped off.
I don't have anywhere near that amount of land...thankfully LOL. I use my tractor for moving a yard trailer around in the summer doing maintenance, leaves, driveway, a chipper on rare occasions etc...not many hours, so in that instance an electric would work. In the winter time, I plow mine and my neighbours driveway so 3-4 hours at a time...in the cold. No way would an electric cut it.As to the tractor that is the topic of this discussion, would I be interested in it? Nope. I have 70 acres of woods to maintain plus 700 acres of farm to be worked with the family. That is a lawnmower not a tractor. To a guy with 5 or less acres though, that would be the cat's meow.
Diesel locomotives are powered this way and have been for half a century. Really very simple in theory, but in practice regulations and the desire to implement electrical systems into everything make it more complicated than it needs to be.I understand your reasoning but then you have two power sources to maintain, batteries, electric motor and generator plus control electronics and a diesel engine so I don't see the advantage.
Yes. I think making heat is the downfall. A diesel fired heater might be a good solution, but again. Two systems and still burning fuel.I don't have anywhere near that amount of land...thankfully LOL. I use my tractor for moving a yard trailer around in the summer doing maintenance, leaves, driveway, a chipper on rare occasions etc...not many hours, so in that instance an electric would work. In the winter time, I plow mine and my neighbours driveway so 3-4 hours at a time...in the cold. No way would an electric cut it.
I thought that was because of the high initial torque requirement to get thousands of tons moving, I could be wrong tho...usually am LOLDiesel locomotives are powered this way and have been for half a century.
Good luck...that's a losing battle if there ever was one.Really very simple if you could keep the epa and technology nannies out of it.
