Has anyone here replaced the halogen bulbs in the work lights with LED's? I added the ROP's work light kit and rear work light kit to the 1025R today and in the instructions it said the switch could not handle more than 3 lights. Well I already have the fender mounted lights and the wiring diagram shows all are on the same circuit. Sooooo I figure if I change out the halogen bulbs for some LED's that will greatly reduce the load so the switch will not be over loaded.
Question is has anyone done this and what did you use and how do you like them? I am definitely going to do this but why reinvent the wheel, light in this case, if someone has already figured out what works best.
