Not sure there is such a thing, but the last time I hooked up, all the lights worked till I got to my destination, found the R turn signal out. The bulb is good, but fits loose in the socket. I needed a way to check the lights without having to bring the truck over and hook-up. I have a good spare GT battery, so I made this adapter (fused) so I can connect to each lamp at the connector so I can try and tighten up the bulb sockets. So far this is un-tested (watching the race) but I'll give it a try later today. What do you think?
