1 - 6 of 6 Posts
After winter fired up the zero turn. One of the front tires was flat. I remember reading a post about tieing a belt around the tire to get the tire to seat on the rim. But I don't recall exactly how to do it.
Could someone please explain how to get the tire and the rim in contact so I can get some air to stay in there. Thank you.
Jack the tire up, along the circumference tie off the tire with a rope with small loop in it. Then while it's filling up put a small pipe in the loop and twist it tight so the twisting rope helps the tire to seat on the rim. good luck.
The Link King
Spray WD-40 liberally around the open bead part. Stand back and ignite with a lighter or some other flame. The tire will seat itself:fing32:
This can also be done with ether. Just be really careful if you try this. Its not really the best thing in the world for a tire........
I've read of that method before and in my opinion that rates a notch above telling someone how to disable safety switches. But that's just my opinion and most everyone has one.
1 - 6 of 6 Posts
