I have a z445 with a Kawasaki FH721V twin engine. I believe one of the cylinders is not working. When I pull the plug wire off the back cylinder, the engine shuts down and will not start unless I plug that wire back on. When I do the same to the other cylinder, it has no impact, the engine keeps running fine as long as that back cylinder wire is attached to the plug.
I replaced the ignition coil today to see if that would fix it, but no luck. also has new plugs now, new filters, etc.
Any ideas?
Any ideas?
