Welcome to the forum!
If it has a choke control, does adding choke make it better, or worse? If adding choke improves things, then you're running lean, and not getting enough fuel. If adding choke just makes it weaker and maybe produce black smoke, then it's likely not a fuel mixture problem.
If you had a video of it running, that might be helpful.
You're getting spark, since it runs, so that implies it's not an ignition-related problem. Is the gas cap exposed, so the rain could have gotten in? I guess you could have gotten water in the gas.
You can also check the new spark plug and see what the end of the plug looks like. If it's black & sooty, etc. The plug appearance can give clues into how the engine is running. This is one of many resources that describes trying to "read" your plug:
https://ngksparkplugs.com/en/resources/read-spark-plug
