YT3000 blade engagement cable
629 Views 7 Replies 3 Participants Last post by  chops1sc
I replaced the PTO cable but the new one is setup a little different. In the attached picture the top one is the old cable. The new one on the bottom looks different and I assume it uses some type of pin to secure it to the bracket. Anyone have any idea of what type
Of clip I need?
1 - 8 of 8 Posts
Do you still have the clip from the old cable? I think it would probably work.
Cannon
That’s the thing, there was no old clip. It was held in place by the cable housing itself. The new one has no built-in clip.
Is there a parts diagram for it, that shows the separate clip now for the revised part?
But, I would expect either
1) it's the wrong cable
2) the cable would have the clip attached to it (ie, they would come as a set, not individually)
Maybe contact the seller or look on the parts diagram to see? Or contact another vendor to find out?
Assuming it's the right cable you will need a clip like this.
Cannon
Yep, I ended up using a small hitch pin. Along with some rigging.... Don’t laugh, it works! It’s an old mower and I couldn’t wait anymore, lol! I did eventually weld the nuts to the u-bolt so it couldn’t slip down.
That black ring on the cable is supposed to be behind the clip. If it matters.
Sent from my Moto G (4) using MyTractorForum Free App mobile app
Yeah but it wasn’t enough to take up the room. The new cable end is deeper/longer from where the clip sits to the bracket. The u-bolt was the perfect size. I imagine the new design fits a thicker bracket.
1 - 8 of 8 Posts
