I got a steal of a deal on this tractor, $157 on eBay for the tractor, 38" deck, 36" blower, weight box, chains, all the original manuals which i just found in another box. The deck is in good shape, little surface rust i plan on sanding and painting over the winter to be ready for spring, needs the blades sharpened but otherwise they are serviceable. Blower works great and doesn't appear to have much use, needs new skids, after spending time looking at them today i think they died a slow death from sitting on the wet cement floor where it was stored rather than wear from use, new ArmorSkids on the way for that.
The only bad part? Its a 935015 so it has the KawaCrapi 12.5Hp engine that loves to have valve and valve seat problems. This one had three loose head bolts, retorqued and put in a new plug and oil and gas and i did manage to get it to run and drive, albeit running poorly and LOUDLY, man these suckers are loud, of course i think the muffler might have been rotted a bit also. I gave up on this engine, wasn't going to put anymore money into it.
I invested in a B&S 13.5hp Intek, cast iron bore, model 21B907-0029 which should replace the Kawa nicely. Have to make some minor wiring changes, the B&S is a dual circuit alternator, 14v AC for the lighting, and a 3a DC output for battery charging. I also need to add a starter solenoid, the Kawa had a starter with solenoid on it, the B&S of course does not.
I got the engine pulled, power washed everything, got it all degreased and clean, and all the wiring modifications done except for the wires that go to the engine, still hanging free waiting for engine so i know what length is needed, connectors, etc.
Work left to complete...
Install pulley on new engine
Bolt in new engine
Install drive belt
Connect wiring
Connect fuel
Connect throttle
Test Run
Reinstall Hood
Install new skids on blower
Then this winter i will go through and rebuild deck for it, bearings seem ok, needs new belts and some painting mainly.
Bolt in new engine
Install drive belt
Connect wiring
Connect fuel
Connect throttle
Test Run
Reinstall Hood
