Hi
Just thought I'd post a picture of my ballast box. I mounted a 1 1/4 in. reciever on it and have a hook mounted on a ball mount. Used it the other night to pull a big stump up out of a hole so I could put it in the loader and dispose of it. Worked great! The reciever is actually one end of a 2in. to 1-1/4 in adapter. I cut a 2" square hole in the box and bolted the adapter to the bottom. I then put 4 half in. bolts in the corners of the box to act as feet and prevent the box from balancing on the adapter mounting bolts. It required some elbow grease but no welding.
Brian
Brian
