It does seem to be the month of the M's.
Only real problem I had was that the plastic ones were prone to breaking on the rears. I had a Proline I bought cheap and I put 2 new drive wheels on it and then ended up not using it, so I robbed the wheels off of it once I learned they also fit on the LB mowers. This was 10 to 12 years ago...Whats up with the wheels? Did you have a problem with the self propell and stuck those on there? Havent seen any like that.
I wonder if it's the type of plastic? I've seen the "Fusion" paint for plastics and I figured it would work, but I really don't want something that will just scratch or flake off.Awesome wheels.....My all time favorite wheel. I never thought to put them on a LB before...but then again I'm mainly using prolines so I don't have a reason to put some on a LB.
That plastic is tough to paint...I tried the very same thing and it looked good for awhile but the paint scratches off easily....or at least it did for me....you guys are much more talented than I when it comes to doing stuff though....
Not a bad idea... I was looking at the trans while I was cleaning and pondering tearing it apart. What type of grease is best to use in those? What about it makes it tricky? Just cleaning it all and getting it back together the right way?If you haven't done it yet, I recommend a repacking of the trans. Tricky but worth the effort and insurance to help keep failure low.
I guess I DO have a service manual! Thanks for the tips, it sounds pretty complicated! I've never had one opened up... The too much/too little grease is the tough one. Hopefully the manual specifically lays out how many ounces it needs.Basic #2 lithium base grease like all other LB transmissions require. You have the detent check ball that locks the gears 1,2,3 with a small spring tab. The steel ball is smaller than a B.B. You also have a couple bushings on the axle that must rest one way when you put the case halves back together. I've done 2 of them still bolted in, and others here have done them with the axle removed which may make it easier. This trans is easy to overfill with grease. Too much can cause it not to lock in gear correctly or jump out of gear you could say. Also need to prep and reseal the case with a very thin bead of RTV silicone. Make sure you read the manual before you do it for some tips.
Well, clean it good and paint... I don't think there is much more to it than that and if that failed it may be a weird type of plastic that paint just can't bond too.Black Fusion is what I used. I was dissatisfied with the result but perhaps I didn't prep the plastic very well. I just cleaned it real good and started spraying..lol.
So the Prolines will work on an LB. Interesting. I might go that route in the future. You wouldnt happen to have a part number for those would you?Only real problem I had was that the plastic ones were prone to breaking on the rears. I had a Proline I bought cheap and I put 2 new drive wheels on it and then ended up not using it, so I robbed the wheels off of it once I learned they also fit on the LB mowers. This was 10 to 12 years ago...
They will work on the Toro-Lawn-boys ('93-'96), not the pre-toro models ('89-'92), if that makes sense... In other words they will fit on the 10590/10591 models, but not a M21ERB for example, because they used different drive gears.So the Prolines will work on an LB. Interesting. I might go that route in the future. You wouldnt happen to have a part number for those would you?
OK, thanks. I have a m21bmr, but I did the tranny swap with a 10590, so I should be good!They will work on the Toro-Lawn-boys ('93-'96), not the pre-toro models ('89-'92), if that makes sense... In other words they will fit on the 10590/10591 models, but not a M21ERB for example, because they used different drive gears.
I'm having no luck locating the part number for the wheels, but they are the ones that fit most all of the 21" proline models.
Just brace yourself for the prices... Probably looking at around $150 for the set of 4, 2 drive and 2 standard. The lawn boy orange wheels are another option, for about the same price, but I'm unsure of the availability of them now. I bought a couple sets of the drive wheels from es_bob on ebay last year. If you have a good toro/lawnboy dealer near by, you may be able to order them, they were for the LB commercial model that had a very short life on the market...OK, thanks. I have a m21bmr, but I did the tranny swap with a 10590, so I should be good!
The can I bought is a rustoleum brand for plastics, and there's a warning on it that it may not bond well to polyethylene plastics. I pulled the top green part off the air filter cover and see it has the letters "HP PE" embossed under the part number. I'm going to guess "PE" is for polyethylene. That would explain the problem, and create a problem for me!Black Fusion is what I used. I was dissatisfied with the result but perhaps I didn't prep the plastic very well. I just cleaned it real good and started spraying..lol.
