Yanmar 2820D 4WD does not move
4422 Views 9 Replies 4 Participants Last post by  winston
my Yanmar 2820D 4WD does not move forward or reverse. Is there any common problem about it?
on 2nd photo there you can see the gear selector, there is no ligt under display, can it be the problem? no electric power?
http://www.mytractorforum.com/images/smilies/MTF_wel.gif
1 - 10 of 10 Posts
Can't pick up your pictures. I don't understand "there is no ligt under display". I don't think electric has anything to do with shifting or gearing or moving. Is your range shift in a gear and not in a neutral position? Does the 3 point and any other hydraulics work as they are suppose too?
I'm not seeing any photos either.
MikeC
are 3 pictures visible now?
Yes, your images are out there now. My first time to see a grey with the lighted gear position indicator. However, shift linkage is still manual. You must have power steering also?
Want to answer my earlier questons?
Yes I got power steering. I will be back home in 2 weeks and check if lift works, but last week the PTO was no running, that is wat my father told me.
The lights on my 2620D don't work on shifter so that isn't an issue, make sure you have enough fluid in transmission.
I do remember my tractor was getting slow, I changes filter at back of rear end by PTO shaft my filter is behind a triangle shaped plate below PTO and offset to the right a little bit, I don't know if your tractor is the same, after I changed it the tractor ran like new.
Mike
If pto is not working then you either have a clutch problem or possible splined coupling on the shaft that goes from clutch to transmission. This item. Yanmar Tractor Parts SPLINED COUPLER _
the lift is working, but I tried to engage PTO but it does not work! maybe I do something wrong? On the left side I have 4 positions PTO 1-2-3-4, do I have engage it somewhere else? Is there operators manual tor Yanmar 2820D to download? Every descryption on my tractor is in Japanesse:)
Might check with Hoye about an operators manual. Yanmar Tractor Parts Yanmar Operation Manual
The pto should work in any of the 4 postitions. If the tractor will not move and the pto does not work you either have a bad clutch or splined coupling. Tractor will have to be split to find out which. Already stated this but not sure you understood.
1 - 10 of 10 Posts
