Well I guess I have gotten myself into a quite a project. I recently purchaced this Beauty......$850
http://rover.ebay.com/rover/0/e1140...tem=250910185384&ssPageName=ADME:L:OC:US:1123
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=250910185384&ssPageName=ADME:L:OC:US:1123
So the first order of business will be getting the engine squared away. As per the seller, the engine is showing low compression. He was planning to simply lightly hone the cylinders (he inspected the cylinders and said they are still very smooth), replace the rings, put the head back on and go (he said the head looks good).
I am probably going to take the head in and get it resurfaced and have the valves tested as well. While I'm in there i will clean the oil pickup and maybe test or replace the oil pump.
I would appreciate any advice on whether or not this is a good game plan (can you detach the rods and push the pistons out the top by dropping the oil pan or will I have to disassemble the whole engine?) what other work should be done while i'm in there.
The good news is I've got a big barn and all winter to get her running. I bought the I&T manual today. I will pick up the tractor soon.
Thanks all.
Daniel Franke
Thanks all.
Daniel Franke
