Trying to figure out what happened to my X729.
When I turned the key, the fuel pump came on as normal. Then I pushed in the brake pedal and turned they key - and got nothing.
The hour meter display is blank.
I put a Battery Tender charger on over nite. It says the battery is charged, and a volt meter shows (edited) 12.8 volts across the terminals, and at the starter bolt.
I removed the left side grill, and all the fuses look good, and check good with the ohm meter. There is a bit of corrosion on some of the fuse spades and the female ends, so I pulled them in and out a few times to hopefully ensure a solid contact.
Still nothing, and the fuel pump does not come on for a short period of time anymore when I turn on the key.
Any ideas?
Thanks in advance.
Any ideas?
Thanks in advance.
