X700 series is not dead for 2011 But 2305 is
21175 Views 102 Replies 34 Participants Last post by  Cat385B
The X700 series is not dead for 2011 there will be X700 series for 2011 it was not replaced but the 2305 will be replaced by the 1023E and the 1026R the new 1 series tractor's
1023E
22.3Hp
independent Mower lift
Auto connect mower
Auto Hitch
Higher loader lift Capacity
1026R
25.5hp
Auto connect mower
Auto Hitch
There will be two new loaders
H120
D120
H120 it will have more features over the D120 Quick Park (similar to 200CX loader) oil Line covers,Mechanical bucket level indicator,and In Base.Quick-Tach carrier with choice of Bucket
D120 is a parkable loader suited to Value minded customer''s who still have Heavy loader needs options are limited to ensure easy ordering,quick delivery and consistent inventory
The H120 and D120 will not be compatiable with the 2305 or 2320,2520 or 2720 tractors
The D120 & H120 loaders have a greater than 25% increase in lift capacity on 1 series tractors over the loader lift capacity on the 2305.
As of the Cincinatti Ohio show the X700 series is still in the 2011 line up effective date on new info 03sept 2010 Hope this clears some of the mis information on the X700 series tractors.
1 - 20 of 103 Posts
1023E
22.3Hp
Auto connect mower
Auto Hitch
1026R
25.5hp
Auto connect mower
Auto Hitch
H120
D120
Wow, great info Sergeant! Thanks!!
So, this is all consistent with the new model designation scheme, right down to the R & E versions (value and deluxe).
Could someone explain the significance of "independent mower lift", "auto connect mower", and "auto hitch"?
Also any info about backhoe capability?
I assume that all-wheel-steer and all-wheel-drive are not part of the package?
The back hoe will still be the 260. The auto connect mower you drive over the deck and list for two clicks then raise mowing deck and it connected Look under build & price on JD web site under the 3000 series tractors. For auto hitch you can connect implement to the Rear PTO with out leaving the seat just reaching back and moving one leaver again see JD web site under Compact utillities under Build and Price. Indepentdent mower lift was a option on the 2210 & 2305 it is now standard meaning 3point won't move when lifting mowing deck.:thThumbsU
:thanku:
Those are great features.:trink39:
Any sense of dimensions? Same physical size as 2305/2210, or ???? The "spy photo" looks a bit smaller, and the loader sounds like it might be sized below the 200C/X loader.
From the print out I have they llok very simialr to the 2305 They look a little more sloped in the front and do have foldable ROPS The brusch Guard look just about like the brusch Guard for the X700 series only thicker tubing.
Good info Sarge. The gas cap on the 1xxx will also be on the fender and not on the hood.
They're keeping a pretty good lid on these, no Google images for either of them yet!!! Sounds like some real improvements, are they calling them SCUT's?
From the Public deere Web site you can't see them Yet but from the Dealers access to the web site they show the 1023E and the 1026R with the D120 & H120 Loaders:thThumbsU
They should be up by October on the Public side of the Web site.
The Gas cap I can't tell by the picture
TBN had a photo up that was removed for copyright reasons. It showed the folding ROPS and gas cap on the fender. :)
Built by Yanmar?
Good question. October will sure be interesting. :)
Auto connect = more casharoo you better have..
From the print out I have they llok very simialr to the 2305 They look a little more sloped in the front and do have foldable ROPS The brusch Guard look just about like the brusch Guard for the X700 series only thicker tubing.[/QUOTE
Could you post the print out?
Boss,
No he can't post that info yet.
Serge it sure would be nice if Deere would surprise us and come out with a 46 Loader for the X7's that utilized this century's design work, with a Curved boom setup :)
Boss,
If JD was really on the ball, they'd make these new 120 loaders for the 1000-series X700-compatible!!
Great info. Looks like JD has been reading some of these forums for some ideas!
UT,
Wouldn't that be sweet :)
A question on the "Auto-Connect" mower, how does the tractor operate it? Driveshaft? Hydraulics? I understand that the mower lift system could automatically connect to the deck, but there has to be some type of human intervention there. Thanks for all answers!!
Joe,
Same as any other setup except they change the ends of the PTO shafts so they can easily self align. There are videos on Youtube of Auto-Connect on a 3320. It's smooth for sure, Costly I bet!
1 - 20 of 103 Posts
