I have a 2007 X540 (sn 61092) and Kawa FD731V. This fall, I started my mower, drove about an acre (no PTO), and shut it off. Went back about an hour later to start it and I got nothing. Lights all came on, but not even a click was heard. This happened one time before, and my husband (who's 2x heavier than me) hopped on and it started right up. So he tried it again this time, and still nothing. Had to tow it home. I took her apart and found several wires that were worn, repaired them, but that wasn't the issue. I checked all connections per the repair manual, and everything is fine. Obviously, I can't do any of the checks for electrical issues that require it to run, but so far I have found nothing amiss. I even did checks on all the safety switches, and they all seem to be working great. Took the battery in and had it tested, said its running at 12.8V. I have cleaned it all up of years of grime and grass (I'm tough on the old girl) and whatever I have done, I finally got a click in the fuel shutoff solenoid area. That's all it will do. Today, after a bit more monkeying, I got it to <cough> once, where it sounds like it wants to crank, but its a short burst that sounds like a fuse blew on something you're trying to start. Then I try turning the key again, and silence. Today, I also tried jumping the starter that we replaced last year and all that happened was a whirring sound, like a blender that the teeth aren't grabbing. But it won't start. Before I start taking the radiator off to get at the flywheel, I think I should stick at something less deep. It seems like it should be simple. I have never had any real issues with her at 840 hrs, except for wires that rubbed through and caused overheating. Seems like even just an annual inspection costs over $1000 at our dealer. Having just lost my job due to an injury, I can't really afford to run her back to the dealer to find out it's something stupid and easy I could have done. I am quite handy (even for a woman), have the desire, some tools and a lot of stubbornness. Hoping someone can point me in the right direction because I am frustrated now.
Oh! and the manual gave direction on how to test the starter but I am lost when it says to check the purple wire. There are no purple wires that lead anywhere near the starter. The voltage regulator, yes. But not the starter. Since the schematics are backward in the manual, and I found that they referred to another couple purple wires as "brn" (zero brown wires in the whole machine), I assumed this was another oversight/typo but all the different engine types say to check the purple wire. There is one red one from the battery and a black one connected to all the others/ground. ugh
