X530 frt weight bracket
5992 Views 15 Replies 8 Participants Last post by  wizzo
On my x530 i have the front weight bracket which limits how high i can raise the snowblower. i wanted to remove the bracket to get more lift but the hood is fastened to the bracket. Are there other smaller brackets i can get for the front of the hood? :thanku:
1 - 16 of 16 Posts
Try the one that comes std on the X500.
Event if you take off the weight bracket the blower lift capacity is limited by the mount stopper.
I would imagine it is not recomended to try to alter this? It would be nice to be able to lift the blower a little higher.
I guess you could try the X3xx/X500 front bumper (a few of us X500 owners have a spare bumper because we upgraded to the heavier front bracket) and possibly shaving some material off of the mounting bracket circled in red on the left above... Of course that might weaken the bracket a bit and need for a slight reinforcement on the back side???
The most important thing to consider it's the snowblower pulley angle, in the picture below you can see in blue the angle of the big pulley, too much angle and the belt will get off.
Yes, pulley alignment (akin to fleet angle) is critical on this arrangement. In fact, when my blower was delivered, I had a heckuva time keeping the belt on. Fortunately, there was a bit of adjustment available in the elevation of the driven pulley (two setscrews on the underside of the pulley) to allow raising the driven pulley and remedy that problem. Throwing the belt must be a rather common complaint because JD issued a bulletin regarding this issue. Raising the blower to a higher elevation, and thus raising the driven pulley, would only contribute to this potential problem.
Well yes because you lift the blower an additional 1/2 inch or so from full up position to remove or install the belt more easily 2X4 flat works well, on the dolly deck. or have another person lift up for you.
That is good to know, I learned something new today (pulley has adjustment). The first time I engage the PTO on my new X540 the belt came off the 47" blower. Not a good first impression. I adjusted the lift height a little and found it would still do it if I engage the PTO when the blower was raised. Since then, I make sure the blower is down when engaging and have not had a single problem since. I'll keep that adjustment in mind if things change. Im surprised JD does not send out a letters to pertaining customers to advise them of the bulletin, issue, and remedy. I know it is probably a way to save for them but it would be nice to know without having to talk with a dealer to find out.
When I did the maintenance on my snowblower last fall I discover that the idler pulley angle as to be perfect otherwise the belt will jump off when the snowblower is raise.
The pulley on the left should be slightly bent inwards to keep the belt on the large pulley and must run in the middle, otherwise the belt will frayed.
It cost me two belt to learn that. :banghead3
Here are a couple of pics of the weight bracket that I added to my old X500. This should be the same bracket the OP has put on his X530. As you can see in the pics the new weight bracket comes out and down. It hangs down a good couple inches lower than the stock front guard that the X500/X530 come with. I think this is why the OP can't get the lift he wants.
Bingo 8086bruce, you have it exactly :thThumbsU
I completely forgot about the new design bracket. :duh:
You should have post a picture of your setup. :)
When the dealer installed the front weight bracket they neglected to give me the standard bumper and they don't have it now so they ordered one for me.
http://salesmanual.deere.com/sales/...attachments/bm23621_front_weight_bracket.html
Bummer. After taking off the weight bracket and installing the stock bumper, i did not get any higher lift. Oh well live and learn. When the weight bracket goes back on in the spring i won't have to worry about taking it off again.
One less thing to occupy my time.
:sorry1: To hear that the original bracket didn't help.
1 - 16 of 16 Posts
