Hi. (First post with pictures.)
I bought an x500 early last month (October) after having my third MTD machine die in 15 years. My neighbor has had a JD for 11 years with no issues other than routine maintenance.
I went to a local dealer and bought an x320 on an impulse. After having it at home for a few days, and also reading here about the transmission tradeoffs, I went back to the dealer and traded up to an x500.
When I get something, I typically start modifying it to suit my needs and taste. The x500 was no exception. I purchased a 44" blower from the dealer when I bought the machine. I then immediately bought a JP electric sleeve hitch. Again, this forum was very helpful to me in sorting through the issues.
Here is what the JP sleeve hitch looks like mounted.
I then wanted a back light, but wished to do so without modifying the tractor. Throughout my mods the goal was to add features without changing the tractor as it came from the dealer. I added the back light by using plastic cable ties to fix a small strip of plywood underneath the back, using the predrilled holes for the cable ties. The advantage is that the plastic tubes project below the seat pan and provide a space for wires to be run between the wood brace and the seat pan.
I added a magnetic light, shortened the cord (using two layers of heat shrink, with electrical tape over that) and added a lighted switch (more on that later).
