What tiller do you have? The tractor's hydro pump won't supply enough flow to power a tiller. The Deere tillers run a pump driven off the mid PTO.
Yeah, most X700 (X4x5/X5x5) owners would get one that is shaft driven by the rear-pto, like the 647 (see Rubadub's photos). Much more common than hooking up a pump to the mid-pto.What tiller do you have? The tractor's hydro pump won't supply enough flow to power a tiller. The Deere tillers run a pump driven off the mid PTO.
If I'm not mistaken, with your 2WD it's about 4.5 gpm total (the 4WD versions have about 6 gpm). But a big chunk of that is for the power steering. So you probably only have 2-3 gpm available for hydraulic implements.What gpm can the pump supply? I got a H70 ingersol tiller.
