... Forgot to mention it has a 48" deck. any problems with that deck on such a HD tractor?
I haven't heard of any problems with the 48" deck. The 48" deck is essentially the same width as the X475 (which is about 46-47" wide.) It seems most folks prefer the larger 54" and 62" versions, because they can trim closer to edges, etc. You could always watch for a larger deck if you needed it, and there are sometimes folks with gate issues looking for the smaller 48" deck.
But as far as it not being heavy-duty enough, I wouldn't worry about it. It's designed as a shaft-drive deck and to work with these machines just fine.
Also, when I said earlier that the X475 is the equivalent of today's X700, I should have been more clear. What happened was JD changed their numbering system for these tractors, and re-named them the X700 Series. So the X475 isn't so much the "equivalent", it really
is an X700, just going by the old name.*
Hopefully Sergeant will come along soon and show you some pictures of his X485 with the front-end-loader.
*There are lots of other versions of these: X465, X475, X485, X495 (all 2WD). Then there are the X575, X585, X595 (all 4WD). The X495 and X595 have diesel engines. So you can watch the classified ads for these models as well if you are trying to shop around. Take a look at this chart that fellow MTF member POENY made to help folks decipher the models:
X700 Series Family Tree
