1 - 10 of 10 Posts
All,
I've been lurking for the past month or so, and want to thank everyone for all the information I have learned. You guys are great!
My wife and I recently moved from an apartment to a house on a 0.4 acre lot, and are looking to buy a mower. Our budget is around $3k. Our lots is fairly flat, but has a small (~3 ft drop) ridge that is probably a 20-25% slope. There are a few small trees.
My dad works part-time as a delivery driver at a John Deere dealership, so he has been keeping an eye on the used inventory they have in-stock. Recently, they got an 2013 X360 with 420 hours on it and a 48 inch deck. They are asking $2,995 for it, but my dad should be able to get a discount.
If I were to buy a new mower, it would most likely be an X330 with a 42 inch deck ($2,999). Currently, John Deere has a promotion for $300 off the X330, plus my dad may be able to get a small discount.
I would only use the tractor for mowing, plus maybe pulling a light wagon with garden supplies.
My question is whether I would be better off getting the X360, which is the better mower, or the X330, which would have the warranty plus fewer hours.
Thanks in advance for your help!
Obviously the X360 is better tractor, bigger better engine and stronger tranny. 3k for a 6 year old X360 with 420 hours, is way too much money, sounds like a dealers starting point. I’d try to get it down fewer than 2300 bucks. For instance two years ago I bought a 2012 X310( K58 tranny) with 55 hours on it for 2K. I’d pay max of 2500 if tractor has solid maintenance record and in impeccable condition
Just for perspective, my lot is double the size of yours and I cut it with a GX345 with a 48" deck. I cut 20 - 25 times a season and put 10 - 15 hours on my tractor per year cutting grass. A 3-foot drop is a non-issue.
Either tractor will last you a lifetime on that yard.
As a side note, demand for tractors has pretty much dried up this time of year the Denver area. If it were me, I'd probably offer $2k (assumes solid maintenance record) for the X360 and buy the X330 if they say no the offer. Of course, that assumes you don't have a gate that precludes the 48" deck.
Keep in mind, you will be doing more maintenance on the X360 with those hours - things like belts, spindle bearings, idler pulleys, etc.
I'll throw out another option if you go new. I'd go up to $3,299 for the 42-inch X350 in order to get the Kawasaki engine. The $300 cash back offer applies to all X300's right now.
X360 all the way, X370 new if you can get a good discount, better engines, better trannys, and you'll love the power steering and lift. PS: the wife will like it so much you may just be Mr. Maintenance Man!
I didn't want to spend too much of someone else's money, but I'd second the thought of the X370 on the new side. But now we're 25% over the original budget. See what dad can do - it's toward the end of the mowing season.
Power steering is something that sounds like total overkill until you have it, and then you realize what a wonderful thing it is. Plus, the X300's with power steering also have bigger trans that's user serviceable (you can drain/fill the fluid without removing the trans from the tractor).
The X360 is still more tractor though. When the X300 series got a little redesign in 2016, the X360 changed names to what's now the X390. The 2016 design change put in a new instrument cluster, changed the "dashboard" controls a little bit, and introduced the current Accel Deep decks.
Thanks, everyone. I did some measuring on my property, and I think a 42-inch deck will be best.
In regards to the X350, is the Kawasaki engine worth $300? For my application, will I notice a difference?
I will also keep my eyes out for an used X370 with low hours.
No for your application, not that big a difference and if you want the Kawasaki engine- look at the S240-- another very good option for you
1 - 10 of 10 Posts
