1 - 20 of 22 Posts
have a question. My neighbor just purchased a used x320 with a little over 100hours on it. He got it, because I have a x320 that I purchased 3 years ago and have never had any issue and kept telling him how much I really liked it. He had a old cub cadet that finally died and ran across the used x320 and picked it up. We both have about a 1.5-2 acre lot, and I have mowed with his and it is noticable to me that his does not run as fast as mine or pull up slopes like mine. He has noticed it as well because he used mine to test before he bought one. Well we have parked them side by side, checkd his belts,looks at mine, everything appears to be the same.
His mows and runs great, but is slower. Well I guess you can say we may not have enough to do, but took my gps, on his wide open about 4.8mph, mine around 5.3-5.5 owner manuan says top speed 5.8mph I think.
Now the wired thing is his does go faster in reverse. Well I remember seeing a post on here once where someone described how to adjust some linkage so that will go faster in forward which will make it go slower in reverse. We checked the drive belt, his does look a little more worn than mine, but basically seem to be same tightness etc.
Any ideas? His mower runs and mows great. We put new plugs and fuel filter in his and changed oil, dont think it is anything wrong with his tranny because it does pull and mow great, but we now just curious. His has about 115 hours on it, mine has 80, maybe just more wear difference from 80 to 115, but any idea, thanks.
One thing I have always done is use seafoam in my gas tank. I actually ran out of gas once and then when i filled tank back up, it surged up and down and did not seem to have as much power, put some seafoam in and after a few minutes that cleared up. Put some seafoam in his, but still can notice the difference in speed. Engine speed seems the same, just moving speed. We greased everything, hoping some of the knowledgeable folks on here may have an idea. oh almost forgot, tire pressue on his is what owner manual says.
thanks
I think the key is in the hydro control linkage.
. I think if the linkage is reajusted you would speed-up foward and slow down reverse.
steve
could that harm the transmission, would that make a difference on slopes?
I think the reason why it seems to go up slopes slower is because it is running slower. I am not sure, but with the knowledge on this site, I am sure there are folks that know.
Could someone show a picture or explain how you would adjust the linkage.
Thanks
A simple fix. You need to adjust the pedals so that they both come up as far as they can. There is one bolt per pedal along with a locator peg as I recall. Loosen the bolt enough to move the pedal on the linkage. Force the pedal up as far as it will go while holding the linkage so it doesn't move. Retighten the bolt and do the same on the other pedal.
Thanks
Will get with him and take a look
thanks
great site,
Discussion Starter · #8 ·
will try this in a few days. Does anyone know if there is any kind of service or tech bullentine on this. Just curious. thanks
Run ahead of the pack
Some owner report sometime they come like that form the factory.
From my memory the gas should be at 1.9 ~2 inch from the board.
I kinda like having a little extra speed backwards because those models are pretty slow backing up. My gx 345 probably will go 5 mph in reverse which I like. It goes a bit faster forward 7 mph I think.
Discussion Starter · #11 ·
Here a pic of the adjust slot, one for each pedals.
Thanks for picture, it helps a lot. Here is a picture I took of his forward pedal. If you look it appears that the pedal could be lifted up quite a bit. I looked at mine and the nut is more in the opposite direction than his, which is the way it is in the picture that you posted. Question - If you loosen the nut on the bold will the linkage move. We are going to adjust it one night this week, but want to wait until I find out from folks on this site if it looks like it should be raised. Just looking at it and comparing to the picture you posted, it appears his needs to be raised quite a bit more, and then I will adjust mine as well. Also, his reverse pedal looks like it could be raised quite a bit as well. Checked the drive belts on mine and his and they appear to be okay, not exactly sure how tight it should be. If anyone has a copy of the tech manual that may show and explain how to check and adjust the drive belt, could you post a shot of those pages? Thanks
Discussion Starter · #12 ·
here is another shot of the pedal with a ruler. Not that great of a picture but it appears that the 2 inch mark lines up with about the middle of the pedal
"how to check and adjust the drive belt" answer: You don’t have to adjust it, it is spring loaded.
"If you loosen the nut on the bold will the linkage move" answer: No the linkage adjustment is at the other end of the rod, you only adjust the forward/reverse mechanism by loosing those bolts.
Here's a tip on how I adjust mine, when the pedal is all the way push, she should not touch/hit the floor board.
This way you have the full travel.
Discussion Starter · #14 ·
Thanks, always look for your post or replys. It just appears that the pedal is too low on the forward and reverse. I do not have the tech manual, going to purchase it. The pedals will travel all the way down and touch the floor board. I read on some other post that it should be 1.9 inches from the bottom of the pedal to the floor board. Would this be, if sitting on the tractor, the part of the pedal that is closes to you or the part of the pedal that toward the front of the tractor. If you look at the picture I posted, you can see that the part of the pedal that is closes to the driver is very low if it should be 1.9 inches. Thanks a lot, can see now where the tech manual is worth the money.
Discussion Starter · #15 ·
Question about the drive belt, how loose should it be, if you was to push on it fromt the side, how much travel should it have? Thanks, trying to learn everything I can.
Discussion Starter · #17 ·
Thanks to everyone, we raised the pedal up like everyone described and would not believe the difference in his forward speed, felt like it had more torque on the slope, could have been our imagination, but big difference.
So much, now we going to adjust mine saturday, only thing is, I assume this will not cause a problem with the tractor. We stopped by the local jd dealer and they must have thought we was crazy, we took a small ruler and checked the pedal on 3 x320 and a couple of x500 on his show room floor, and there was a big difference. Some where right at 1.9-2 inches, some where as low as the picture. Makes you wonder why this is not described in the owners manual, or part of what they say they do when you buy one and they set everything up before they deliver it.
Now you got me thinking, Both petals on my new 530 bottom out against the floor mat. Guess I'll have to see if they need adjusting although forward and reverse both seem normal to me.
Correct:thThumbsU
Discussion Starter · #20 ·
His use to, checked mine and it bottoms out as well, but now his does not quite bottom out. I am a beliver now, and convinced before jumping into something, asking on here firt is a wise thing to do.
1 - 20 of 22 Posts
