When I put the height adjustment wheel, at say 3.5 to 4 inches - I notice shortly that it seems to always settle down to the 2.75 level on it's own. It doesn't like staying any higher than 2.75. Is there a simple adjustment for this?
Thanks,
rich
when i first got my X500 it did the same thing. basically the dial was reversed, set it high it went low and low it went high. i had to sping the dial all the way aroudn to get it back right. i think i had to lower it, then spin the dial around so that it read the height the deck was. after that mine has never been off. and the X500 has the same lift system as the X3xx.
Thanks David! I will try that.
I dialed it down to one,,,kept rotating counter clockwise until it hit 4 inches. After a small tour around the lawn, that seems to have done it, although I don't seem to understand the logic of it. I'll do a real test of it when the grass is ready for cutting again.
