Status
Not open for further replies.
21 - 34 of 34 Posts
One more bit of Tech to add, unless someone has questions, with respect to Bolt #8 and Nut #7.
This applies to all X3xx and X5xx series machines.
If you are removing the transaxle, do not spin/rotate/turn those nuts. Only turn the bolts. The nuts are swirl head lock nuts and will gouge the **** out of your hitch plate, leaving UGLY bare metal. I got this tip from a buddy, who is a former Deere R&D team member in Horicon, Wi. It's best to remove the transaxle from the hitch plate, then use a small impact gun on the bolt heads to remove the fasteners. This method doesn't even require a backing wrench on the nuts.
Just thought I'd pass that along.....
I'll never get to 10,000
Nice job!!!
X370 is good, but what about X400 since JD doesn't have an inbetween model like that?
Nice job!!!
How about X370SB or X400SB?
wow looks cool!
great work.
curious, with the extra height will the deck reach down low enough??
what does it look like from the rear??
xk370
Discussion Starter #28
It's the same height as an X5xx, mowing shouldn't be an issue
21 - 34 of 34 Posts
Status
