I recently purchased a new x300 with 42" deck, bagging system, and high lift blades (pic attached).
I noticed that I am getting blowout when bagging leaves. Has anyone else experienced this problem? Any suggestions to reduce it? I've experimented with different mowing speeds and deck heights but no major improvements.
Has anyone purchased the JD blowout kit? Does it work well?
Thanks,
Rokal
The JD kit BM20505, works amazingly well on the 42" decks! It's night and day on the amount of vacuum it adds in conjunction with the high lift blades.
MTF Tractor Nut
You need a slightly deeper deck... Get the kit or make your own. I've seen them made of wood, metal and even conveyor belt around here.
