So I wrapped up mowing mine and dad’s lawns. This thing is a hoot! The down sides are that it’s painfully slow and that left control valve is crazy. It goes nice and straight wide open, but the left valve goes from wide open virtually to stop with very little speed difference throughout the range of travel until it gets to neutral position, but is fine from stop to full speed. Reverse on that side is slow. Not sure what’s going on with that valve.
Now that the spindle bearings are greased it’s somewhat quieter, but still a fuzz noisy.
Hour meter doesn’t work, so what I thought was only 910 could indeed be way more than that.
Grass catcher fills up really fast but empties easily.
This being 1st generation stand on, there’s a safety switch on the operator’s platform instead of on a control stick, so unfortunately if terrain gets really dicey I can’t walk behind it. I thought for sure it had a carb problem the first 5 minutes of using it. Come to find out I wasn’t standing on the platform in the correct place so the safety switch was intermittently shutting off the engine. I got into a sticky situation with it in a drainage gully and had to disengage the blades to help it out. However I was able to drive/push it out. My sit down zero turn would have needed help from another piece of equipment to pull it out.
Operator’s platform is not ergonomic. My body is fine after using it except for my feet. Might snag a piece of an anti fatigue mat from the garbage at work.
Kind of hard to hold a straight line. However, that’s probably due to the goofy control valve and my inexperience with this type of mower. With that malfunctioning control valve, I can’t easily subtly slow down the left side. So I adapted to not wide open on the left side so I can speed up / slow down the right wheel to adjust travel direction. Once that valve is fixed it’ll be a completely different mower.
Cut quality is maybe 7/10. New/sharpened blades might cure that but my lawn is still too crappy to obsess about.
Got some funny looks from neighbors and passers by while mowing with this crazy thing. Not sure if that’s good or bad
