Rookie troubleshooter and Forum user seeks suggestions: My Workmaster 55 dash glow plug indicator light quit working three days ago when the key was placed in the #3 position. The weather was in the 55 degree F range and the tractor did start and I ran it a few hours . The engine turned over a shade longer than normal than if the glow plugs had been working . I have not tried to restart it since then. Trying to troubleshoot, I find my Furukawa Calciccharge maintenance free battery electrolite level is approximately 3/4 " below the max line on the battery housing. No plates are visible looking down through the removable cell openings. . I put it on a normal 12 volt battery charger. It started pulling 3 amps and within one hour was down to zero amps. ( I later learned these batteries require a higher voltage , special, to charge them. I have put no distilled water in it to restore the electrolite level.) With a volt ohm meter I find the buss bar between glow plugs is grounded and stays grounded regardless if the key is held in position #3 or not, Does that mean I need to be looking for a short? This resistance check was done with the battery disconnected. With the battery still disconnected the top of the installed glow plugs is grounded along with the lower hex shaped portion of the glow plug body, I checked two of the four. I do not understand if they are supposed to be that way or not. Any suggestions on troubleshooting would be appreciated. Thank you.
