1 - 12 of 12 Posts
I just inherited an old craftsman riding mower. I have been working on it for days and I have no idea what model it is or how old it is. Found this forum through many hours of image searching to find a tractor like mine, and no such luck yet!
I am hoping I can get some help on here!:trink39:
Glad you joined!
:wwp: If you need easy Picture help
Be sure to Register for Your State!
Thanks for the great Welcome!!!
Unfortunately the sticker under the seat has been removed and the whole tractor repainted.
I have no idea what year or model number it is. I really appreciate any help! :thanku:
Sorry I know the pics are HUGE
I don't have any info off hand, but the fact that it's a four speed with a 30" deck should help us narrow it down fairly quickly. It's a 917.xxxxx, Not a Murray or MTD or AMF, that's all I can say so far.
EDIT: If the engine is original we can get the tractor age within a year or two. Can you post the numbers off of the engine? There should be an id plate/sticker somewhere fairly visible.
Thanks!!!!! The internet has not helped me out much and I even contacted sears and they basically said I was SOL.
So this is a definite boost for my morale!
Can you post the numbers on the engines id tag?. That will help us date the tractor.
4K Poster!!!
:MTF_wel2:
It greatly resembles my 10/36 4 speed. It's a 1986, if that's any help.
The numbers are usually stamped on the metal eng covers.
I suggest you tilt the seat up, get low, and take a careful look at the hitch plate. That's the vertical plate at the rear with the little lip containing the hitch-pin hole.
On my machine and others, there is a metal model tag mounted in the upper right corner of that plate--it might be less than obvious unless you are looking up from below the fender sheet metal.
Hope it's there!
Cranky Motorsports
I would venture a guess it would be mid eighties model... MAybe like a LT Model?
Light duty (see the stamped steel front axle) made only for mowing.
Originally looked like This here...
I am not sure of the actual part number or Model Name though.
1 - 12 of 12 Posts
