Workin' on a Farmall
7091 Views 98 Replies 13 Participants Last post by  Forest Gump
I brought this tractor home about a month ago and a couple weeks ago I pulled it into the shop with a HF winch. The tractor belongs to my cousin and he wants me to get it running for him. He also wanted me to get all of the sheet metal put back on and give it a good checking over. Hopefully things go well without to many surprises.
1 - 20 of 99 Posts
The owner started a 12v conversion so I will need to complete that with a coil, VR, and wiring for the charging system. I had a coil from my parts 350 that still works and today I tested the alternator that came with the tractor and its good.
Looks like a great project!
Bill
Can't wait to see what this looks like when you're done!
Bill
Hopefully it won't take too much work. I know the engine is good because my brother did an inframe rebuild on it probably 15-20 years ago for our uncle. It was driven around a few times its been sitting in my cousins shop ever since. I will be getting another Farmall tractor project as payment for my work.
cjet69, Is that a Delco alternator? If so you may not need a VR, because the VR may be built in. I have a 12 volt conversion on the Farmall A. The ignition is still a magneto though.
It is a Delco but, its not internally regulated(see link). I have one just like it on one of our JD's.
GM Alternator Identification
I'd go with a 10SI Delco off a 1970's to late 80's GM that has a built in regulator..
Those older externally regulated ones are usually only 37 amp or 63 at most,and the regulators are fairly expensive and don't like sitting idle long periods..
That alternator is a pre 1971 version which is getting harder to find used nowadays,and costs more at parts stores than an internally regulated one will..
The one advantage of the externally regulated ones is you can rig one up to make 110V DC by full fielding the regulator and run some tools with AC/DC motors with it..but you can do that with an internally regulated one too..
The way he plans to use the tractor most of the time the charging system will only be used to maintain the battery. Occasionally the lights might get used.
Cjet69, Thank you for the link I will have to go back and double check the A!:thThumbsU
Here is another article on these: https://www.jalopyjournal.com/forum/threads/generator-help-asap.812606/
Post #8 has a good pic.
And another: older style Delco alternator confusion, 1 wire possible, or not?
I'll be watch this post...
I just bought a 350U that's been sitting a few years.
It's just to cold in Pa. to be playing with tractors right now...
I'm sure waiting for spring.
I made it out to the shop for a bit today. I found some material to make a bushing for the pivot bolt on the alternator bracket. It had a 1/2" pipe welded on and a 3/8" bolt thru it which allowed way to much slop. Now I need to address the tensioner bracket to get it lined up. I had to remove the fan and pulley to access the bolt that holds it in place. The bolt goes into the water jacket so I need to drain the coolant before pulling it out. Looks like I may need to get a longer belt also.
A couple weeks back I tried to remove the bolts holding the fuel tank. They were really rusty and felt like they were going to break. I've been soaking them in ATF/Acetone every few days and today I tried them again. They all came out with a little working back and forth with out breaking any of them. Now I have good access to the gauges for wiring and can also clean out the fuel tank.
I have heard of others having good luck with ATF and acetone. What mixing ratio do you use?
50/50, I think I first heard of this on this site years ago and I've been using it with good success for several years. It doesn't always work, but its better that using a torch on the gas tank bolts. :Stop:
Cool project and nice work, cjet69! :)
:thanku: Austen. I thought I would about done with this by now. To many other projects keep pulling me away, but the rain will help keep me in the shop for a few days. Hopefully I'll make some progress.
Cleaned a bunch of crud out of the fuel tank. Its not perfect,but its as good as I can get it without lining it. The fuel bowl valve can hardly be turned so I pulled it and will tear it down for a good cleaning tomorrow.
Made a parts run to NAPA and picked up a 1" longer belt and a wiring harness pigtail for the voltage regulator. I already had the new VR on the shelf. I think I have everything I need to get the wiring done now.
1 - 20 of 99 Posts
