Hello all,
I live close to the Woods Equipment factory and have several friends working there. Woods is a excellent company for letting employees buy steel , get things cut , bent , painted ect. So my buddy is talking to the engineer that does the fel work and is in the Rand D dept . He tells him I want to build a fel for the 990. The guy knows about the 990's and says it is my lucky day! They are clearing out some of the proto type units they used to mock mounts for different tractors to their fel setup. I bought the LS72 for less than I could buy the cylindars for a build! It is perfect for the 990, bucket is 4 foot wide and 6 foot lift. It has a easy to attach mounting system with pins and a saddle . You simply pull up to the mount , use the bucket to raise pin into the saddle and put pins into holes. it also has parking stands that allow the fel to stand alone when removed. I have a couple issues to work out tho , mounting the pump, hydro tank , and a foot pedal for the tractor forward / reverse. The fel controls are right hand mounted so I need a foot control . How do I upload pictures?
Tom
Tom
