I have a case lawn tractor 444-75 is model number it starts like a champ after a new battery a new cyliniod a new plug got
her running out it in gear nothin no forward no reverse is there something I'm missing to get her moving I am using lever that says forward reverse know nothing about this tractor
Hi Pelts...and
2494036
...I am going to move this to the right forum for the tractor...good luck with it...It has a hydro trans in it...have you checked the fluid level and the filter...
Lever on the front of the gas tank below the seat, make sure its either up or down, not in the center on the peg, thats neutral. Also does the lift system work, goes up and down?
  • Like
Reactions: MARK (LI)
pelts
The shifter for LO - HI is under the front of the seat between your legs (-.-)
Put it in low for work or a slow ride high will make it fly
Don't forget the speed control is how ya slow down
good luck get back when ya try it out, ok
bigman
