An S8D should be a magneto ignition,if it has a coil,someone converted it,there should be points and condensor in the box under the carb,if it has a coil,it should use a coil without an external resistor.If there isn't a condensor and it ran like that someone must have changed it to electronic ignition like mentioned.
