1 - 12 of 12 Posts
Does anyone have a wiring schematic for an early 80's GT?
Bob
I should have said select Murray where it says select manufacturer then hit go and it will give you a huge list of all the Murray models. then pick whatever you want.
What's your model # ?. I should have every tractor from 1974 to 1989. Not sure if OrderTree goes back that far, but they do have a ton of Murray diagrams there.
Here ya go..........
Order tree has a complete breakdown of the parts diagram for the 39004 from 1982 to 1989 If you need anything else. I just wish they would let you copy and past like BBY can do. All you have to do is put 39004 in the model number box after selecting Murry and it will show all of them after you hit GO. They are basically what BBY posted from the few I looked at though, but if you want to go year specific that is an option also.
That's good to know. I didn't think they had the diagrams going back that far. The one I posted was a 1985, I split the difference.
Discussion Starter #9
I just copied that diagram, BBY. Thanks.
I tried going to ordertree.com and inserting the required info and nothing came up. I try again.
Bob
:) Copied these direct from page but not sure they will work as links here
82-39004
83-39004
84-39004
85-39004
86-39004
87-39004
88-39004
89-39004
Discussion Starter #11
On some things you can copy. I did manage to bring up the wiring schematic and copied & pasted and it worked fine. (only because I could blow it up and still be able to read it clearly)
Bob
1 - 12 of 12 Posts
