There are two garages on my property and the closest one to the house my wife uses for her cars and I also use it as my workshop. We'll call this garage #1. Anyway on the back forty there is a garage that is closer to where I keep all my project rigs(wife likes them away from the house) and I'd like to start using this as a part-time workshop instead of a storage building for those days when I don't feel like dragging my works-in-progress all the way over to my leanto in the rain or snow to get worked on. This is garage #2. Anyway, this garage has power to it from the previous owners but it kind of has me scratching my head and wondering if it will be alright to use even as a part-time shop even though the previous owners were.
My electrician father and I upgraded my house from fuses to a 150amp breaker panel about 6 years ago but we did not hook up the wires that use to run out to garage #2 because he said he was going to fix it up the right way for me. He recently passed away and now that I'm kind of getting motivation back to work on projects I need power out in garage 2.
Garage #2 is setup up as follows: There is one 220V wire along with one 110V wire buried together in underground conduit going from house to garage. Those wires are currently hooked to nothing at the basement panel. When they enter the garage the 110V wire goes to an on/off switch which is daisy chained to 4 outlets, one of which has an overhead light plugged into it which seems fine unless I were to run a bunch of stuff at once. My concern is the 220(240, whatever) wiring setup. They just have the 220 wire come in from the ground and to a junction box in the garage and from there it feeds one outlet for a welder and that outlet goes to an outlet they had an air compressor hooked to. Does this seem acceptable to use part-time or should I install a separate breaker box in the garage that feeds each the compressor and the welder? Those are the only two things that are 240V I plan on running out there just as the previous owners did.
In the house where my father left those two wires from garage #2, should I just hook the 110 wire into it's own breaker and install a 60amp breaker in my breaker box for the 240V welder and compressor? Any advice is appreciated.
