1 - 11 of 11 Posts
since i cant find the answer to my other post i decided to use a push button to start my engine but i need to no what do i hook my charging wire to (the wire that charges ur battery) ????
Should go to a Regulator that then goes to your Battery. Is this the Motor you are trying to run on the bench?
iv got a 16hp vanguard v-twin engine came out of a cub cadet thats what he told me....im sticking this engine in a golf cart so i need to no how to wire up a key switch or a push button switch to make it start and while its running it will keep my battery charged
so i need to no how to hook up a 2 pole switch to the engine and how to hook up the wire to keep my battery charged
Sorry, I got links for the IHRegistry that has Cub wiring but the registry is still offline:sorry1:
Discussion Starter · #8 ·
i for got to answer ur question yes this is the motor i have on the bench in till i get it wired up and running right
im just going to go with a 12v 2 pole push button switch to start the engine but now i need to no how to wire that up to the engine
and also need to no how to hook that wire so when the motor is running it will keep my battery charged
The voice of reason !
You're welcome I hope it helps.
It should with all the diagrams and wiring specs.
1 - 11 of 11 Posts
