I have a Kohler 14 HP in my Wheel Horse, circa 1984. At the time the engine oil specs were written, the API classification was SG, ( does that make you feel old? ) and the spec called for SAE 30 for use above 32 degrees F, and for 10W-30 below 32 degrees. Also, very few people were using synthetics in those days. I am pretty religious about using SAE 30, just because on hot days it gives me the assurance that the oil will hang in there for me.
I need an oil change, but I still have some more work to do outside, at times it may be below 32. I was thinking about using a full synthetic 10W-30 in place of SAE 30. I do not put my tractor "away" for the winter", I just leave gas in it treated with stabilizer, and then run it every two weeks or so just to get the fluids moving. So sometimes it gets pretty cold in the garage when I actually do need the lighter weight oil.
What do the people who are more informed than I am think about switching over to the synthetic 10W-30 for all around use particularly in the late fall? Thank you in advance.
