I know a lot of y'all have been waiting on this test.
The Rustbeeter site is down so I will give you the story:
How does Rustbeeter's™ chemical process work?
Sugar beets need iron-rich soil to grow, as they have an affinity for iron. In a concentrated form after being refined, they continue to actively seek out iron oxides. Each molecule of Rustbeeter™ combines with a molecule of iron oxide and the by product of this chemical reaction is water. The net result is no leftover residue.
How is Rustbeeter™ packaged?
Rustbeeter™ is sold as a dry product that is mixed with tapwater. A 5-gallon pail requires about 18 pounds of dry Rustbeeter™ granules. A 5-quart box requires about 4 pounds.
How do I mix Rustbeeter™?
Rustbeeter™ is a food byproduct. Simply mix it with tapwater to produce a loose, pudding-like slurry.
What will happen if I mix Rustbeeter™ with too much or too little water?
If you add too much water, let some of it evaporate out. If the solution appears too thick, add tapwater until it makes a pudding-like slurry. Having too much water in the solution will not hurt the metal part you are treating.
Can I make Rustbeeter™ into a paste and apply it on a part to remove rust?
No. Rustbeeter™ is designed for a soaking process, and thus, the entire part must be submerged in the product. Oxygen in the air affects the de-rusting process.
What kind of container should I put Rustbeeter™ in?
A plastic pail is a good choice, and a plastic container with an automotive type spray-on rubber undercoating will help deter mold growth. The best container for Rustbeeter™ is a rubber livestock pail available at feed stores in 4-gallon to 15-gallon sizes. Note that livestock containers do not have tops. They should be fitted with a cover. If an odd-shaped part will...
What is the largest part I can treat?
Rustbeeter™ is designed for a soaking process, so you must be able to submerge the part for it to work. If you have a part that is too big or long for a traditional pail, then build a container that will better accommodate the part. Making a wooden box and lining it with plastic works well; so do 15-gallon rubber livestock feed pails available at farm supply stores. ...
Does grease or oil on the part affect how Rustbeeter™ works?
Because Rustbeeter™ is a water-based food byproduct and because water and oil do not mix, metal must be degreased before being soaked in Rustbeeter™. Even heavily rusted parts might need degreasing, as the rust will form above the greasy and oily surface.
Will Rustbeeter™ remove paint?
Rustbeeter™ will not remove paint that is properly adhered. However, most paint has rust beneath it and Rustbeeter™ will remove the rust and float the paint.
Will Rustbeeter™ loosen rusted parts?
Rustbeeter™ is not a penetrating fluid. If you have parts that are rusted on, de-rust the entire part and then use a penetrating fluid to loosen the rusted area. Once that piece is removed, degrease and soak all parts in Rustbeeter™.
Is Rustbeeter™ a rust converter?No. Rustbeeter™ is a true rust remover, not a rust converter. It will clean the metal part, not seal or convert the rust. Rustbeeter™ leaves a chemically clean surface that will immediately re-rust without a surface treatment. The exceptions are chrome, galvanized and black oxide parts, which do not need a surface treatment.
Will the metal start to rust again after being cleaned by Rustbeeter™?
Yes. Rustbeeter™ completely cleans the surface of the part but does not apply any protective coating. When de-rusted, the metal will be chemically clean and ready for priming/painting, oiling or waxing. If rust starts forming before the surface treatment is applied, simply re-soak the part in Rustbeeter™.
What will happen if I use Rustbeeter™ on aluminum?
It will destroy aluminum. As a sugar beet byproduct, Rustbeeter™ is slightly acidic. This keeps the product fresh. There is enough acid in Rustbeeter™ to eat aluminum, but not enough to etch steel. Some. Rustbeeter™ will remove gun bluing and Dicromate. It might also negatively affect Damascus steel gun barrels. However, it does not affect chrome, galvani...
Can brass or copper be treated with Rustbeeter™?
Rustbeeter™ will not harm copper or brass. While it will not remove tarnish, neither will Rustbeeter™ damage the surface of the brass or copper.
Will Rustbeeter™ harm soldering, cork, plastic, or Fiberglass?
Yes. It is recommended that you remove metal from wooden parts. Because wood is porous, Rustbeeter will soak in to the pores. The wood might darken and take on a molasses-like odor.
Will Rustbeeter™ clean chrome?
Yes, Rustbeeter™ removes rust from chrome and makes it as shiny as it was when originally plated. Of course, any pitting cracks or flaking from the rusting process will remain. Rustbeeter™ removes rust from cast-iron surfaces, recesses and pitted areas. Due to the high carbon content of cast iron, a slight buildup of free carbon will remain on the surface, givi...
How long will Rustbeeter™ take to de-rust metal, especially heavily scaled parts?
The heavier the rust, the longer the soaking time. An average piece of metal with average rust will be cleaned within three to seven days. Heavily scaled rust will take longer, perhaps several weeks. Knock off loose scale with a hammer and then keep soaking the part in Rustbeeter™ as long as it takes to remove all the rust. There are two types of rust. Red rust is co...
Can I leave the part in Rustbeeter™ too long?
No. Rustbeeter™ does not affect the base metal, regardless of the length of soaking time. Once the rust is removed, the part can sit in the solution indefinitely without harm to the surface.
