1 - 1 of 1 Posts
Precision Application
WM-300 WindMate™ with Lifetime Calibrated Humidity Sensor
In addition to wind speed and digital wind direction, relative humidity, dew point, wet bulb & Delta T make this a comprehensive tool for forestry, agriculture and emergency management professionals.Humidity sensor does NOT require adjustment; it is lifetime calibrated.
Accuweather.com® patented Comfort Index™ gives the effect of temp, relative humidity, wind speed, & sun intensity on the human body. Jackknife case allows the most accurate measurements. Unit can be tripod mounted.
Features:
  • All wind functions in user selected units
  • Digital wind direction in degrees & compass points
  • Cross & head/tail wind readings
  • Relative humidity
  • Wet bulb
  • Dew point
  • Delta T
  • Accuweather.com® patented Comfort Index™
  • Temperature
  • Windchill
  • Backlight
  • Water resistant
  • Tripod fitting
  • Reads in tenths
Specifications:
  • Wind speed accuracy +/- 3% from .8-89Mph
  • Wind speed range to 135Mph
  • Digital compass/wind direction accuracy +/- 2°
  • Temp/Wind chill accuracy +/- 1.8°F
  • Relative humidity, Wet bulb, Dew point, Delta T accuracy +/- 3%
  • Optional Units: Mph,km/h,ft/min,m/x,BF (Beaufort)
  • For C * Avg wind speed over 10 secs
  • Max wind speed 2 sec gust since power on
  • Auto shutdown
  • POWER: CR2032 (400-Hr) replaceable Lithium battery (included)
  • Measures: 5.5” x 1.75” x .75” closed
  • Weighs 3.2oz with battery
  • Comes with breakaway lanyard
  • 2-yr warranty
Shop Wind Meters @ Agrimart.net
1 - 1 of 1 Posts
