No that tiller will not work on your GT3100. It is designed for the Older IH Narrow and wide Frames and will fit MTD designed Cubs up to the Late 80's. Your tractor can only take the Hydraulic tiller for it which uses a shaft driven Hydraulic Pump or a 3point hitch tiller that has its own engine.. I will tell you this once you have used a Hydraulic driven tiller You may never want to go back to a conventional PTO tiller. I have two Hydraulic tillers a 42inch my JD X485 and a 30inch on my Cub Cadet 2206. This is the tiller model number for your machine OEM-190-004. But the plow would work on your tractor with the Cat 0 3point hitch with a Brinly 3 point (A)frame sleeve hitch adapter. :thThumbsU
Wow, looks like I will have to start playing the lottery. I guess I am on the lookout for a used self powered tiller.
Thanks for the info.
Rich
Well that is better than a new one from Cub.........$$$$$$$$$$$$$$$$$!!!!!!
