Will this engine work?
713 Views 2 Replies 2 Participants Last post by  Lawnboy77
Will a D433 fit my 3056?
1 - 3 of 3 Posts
Absolutely that D433 will work for you. Not really much difference between a D432 and D433 anyway.
About the only difference is the flywheel and cover, the D432 has the 3 screw mount for the cover with steel mesh, whereas the D433 has the 4 screw mount with the plastic cover. The flywheels are interchangeable so you can just swap out the flywheel and cover and you will be good to go if you want to stay as close to original as possible.
1 - 3 of 3 Posts
