1 - 3 of 3 Posts
1944 Ford 2N
I have a ford 1600 2 cyl deisel and the go ahead from the boss to buy a 3 PT tiller.
The 1600 is rated at 23 HP and the 'suggested' HP for a 60" tiller is 25 and above. I know i'd be pushing it but a 4 ft tiller will center on the rear tires and a 5 ft will till 2 inches outside the tires. I plan on using the middle buster to break up the ground before tilling.
I use a 5 ft shredder without any issues. Anyone else using a 5ft tiller on a 23 HP or lower tractor?
It should work fine. If you find that you're short of horses, till at a shallower depth and make multiple passes to get to the depth desired. Also sprinkle the ground before tilling if it is dry to soften it up.
1944 Ford 2N
Thanks, sixbales.
I pull a 5 ft shredder and a 5 ft box blade without any issues with it- Wanted the 5 ft tiller to save time and to use with the 2N occasionally, too.
appreciate the feed back...
1 - 3 of 3 Posts
