1 - 20 of 20 Posts
I will be getting a blower this fall, just want to know if 4 weights will fit on the rear weight bracket.
Lord, I would love to see a picture of this:trink39:
Bring on old man winter.
Markcuda, I believe, if memory serves me right, that only 3 weights will fit on the weight bracket. I only used two on mine. I hung them off the bracket for the bagger. I don't recommend this because the Bracket twisted out of shape from the weights.
No s**t?:Stop:
What mower did this happen on?
It was the X360 I used to have. The bracket that's part of frame will hold the weight but the bagger bracket seems a bit weak for the task. BTW that's where the dealer hung them.
Ok, I think I get it now.
I am just not sure I can get 4 of them on there.
I have 2 now, I buy one every now and then, just not sure if I can slide 3 all the way to one side, and then still get on a forth one.
That is why I would love to see a picture of 4 on the rear, if 4 would fit.
I'm sure that if it's possible, this is the place to find out.
Deere 330 Killer
why do you need the extra weight?
Deere 330 Killer
yea. does the amount of weight you have now not cut it?
It was a great machine for what it was. I just wanted something with a bit more muscle for some projects and moving the boat around the yard. I highly recommend the X360 to anyone that wants to mow and blow. It exceeded my expectations with the snow blower. Although, every once in a while diff lock would have been nice. More weight would probably have solved that issue.
Deere 330 Killer
mark, if you want more weight, maybe consider loading your tires with rimguard? its about $0.25 per pound and weighs about 12 pounds per gallon
Discussion Starter #14
I don't want to go that route, if I can get 4 suitcase weights on the rear, that would be 160 pounds.
A snow blower is probably 125ish pounds, but sticks way off the front on the machine.
So, I figure a 160 pounds should off set this pretty good.
Not to mention the extra traction I will get.
Deere 330 Killer
im saying if you cant get the 4 weights on
I'm not sure, but I seem to remember a similar question a few weeks back. I think that someone said that 4 weights will fit, but that JD's official word is that you should only use 2 maximum because you risk damaging the transaxle with the extra weight, but how's the transaxle supposed to know the difference between a 180 lb. person with 160 lbs of suitcase weights, vs. a 260 lb. person plus 80 lbs. of suitcase weights?
The dealer sold me 2 weights when I bought mine. He said I could add a 3rd if I needed to but didn't think I would need it. (I only weigh 180) if I kept it I would have added more.
Discussion Starter #18
I hate to start a new thread, but does any one know what a 44 inch blower weighs for the 300 select series?
I like the persons weight analogy:trink40:
I could weigh 180 pounds, not 270, butt, how does my mowers rear end know I have a big rear end:biglaugh:
1 - 20 of 20 Posts
