1 - 15 of 15 Posts
Ok, I just measured my 425 which is the same as the 445 but with a carb not fuel injection and its 72 inch's long give or take an inch. This is from the front grill to the rear edge of my back tire, which is an ag.
It's also 42 inches wide (not measuring the deck) at the widest point, which for me is the rear tires.
Remember tractor data.com is someone's website that collects data like wikipedia does by having folks contribute. So take it with a grain of salt.
My X520 just fits on my 4x6 trailer. You have to over inflate the front tires for the frame to clear the front wall.
Width & Length of Tractors
X485 for Just tractor No Deck or attachments 47inches Wide By 75inches Long
445 for Just tractor No Deck or attachments 48inches Wide By 75inches Long
318 for Just tractor No Deck or attachments 43inches Wide By 69.5inches Long
Weight or tractor Only Not including deck or attachmnets
X485 855 Lbs
445 815 Lbs
318 836 Lbs
:thThumbsU
Discussion Starter · #14 ·
Nah, but you do need to check the weight capacity of your trailer. It might not have the capacity to carry a near 1/2 ton mower. My uncle had one of those cute 4x8 folding trailers. He found out the weight limitations of that trailer the hard way.
Never would have thought of that- Thanks for the insight!
The Admin from... Nowhere!
My 4 x 6 landscaping trailer will fit my 160 on it, with the deck, but only fits the bagger if I back onto it and hang the bagger off the front of the trailer. It does NOT fit with EITHER the blower OR the blade attached... It's too long with EITHER of them AND neither of them will raise high enough to clear the rails or roll up the tailgate ramp if I'm on level ground with the trailer... And the 160 is ALMOST the smallest Deere you can get... If you don't want to be constantly removing attachments, I'd suggest a bigger trailer. I'd LOVE to have a bigger one!
1 - 15 of 15 Posts
